mopops
removing lean burn going to chry electronic ing and need a 2bbl carb to replace the smog unit, ny idea what carb i could use.. car has A/C n cruze, auto trans tks gjg mopops
my 1987 carb has no dist vac port ,thats why i want to change the carb
will try n see if it works some times theres a simple answer thank you g j gloverIt's been a lot of years but IIRC all I did was move the hose that went to the vacuum transducer on the computer to the distributor vacuum advance. But I'll admit, it's been a lot of years.
