Left Side Motor Mount
Big Block A body Tech
  1. 6PakBee
    6PakBee FABO Gold Member FABO Gold Member
    260
    219
    Feb 8, 2020
    North Dakota
    Local Time:
    3:28 PM
    I've got a 1969 383 Dart with manual steering. I'd like to retrofit with power steering. I keep reading that the rear mount ear on the left side of the block has to be cut off to allow this. Anyone got a picture of what has to be done?
  2. brian6pac
    brian6pac Well-Known Member
    5,328
    3728
    Nov 15, 2016
    N.E.Ohio
    Local Time:
    4:28 PM
    I've never heard that, I wouldn't cut a ear off my block. You need those.
    Do you have a aftermarket mount on there or O.E.
  3. 6PakBee
    260
    219
    Feb 8, 2020
    North Dakota
    Local Time:
    3:28 PM
    The stock '69 383 Dart left side mount bracket does not use the rear block mounting ear. I've just read when you retrofit this car with power steering there can be an interference between the power steering chuck and the rear ear. So it gets removed. I just don't know what it should look like when it's done.
  4. oldkimmer
    oldkimmer FABO Gold Member FABO Gold Member
    19,306
    6463
    Nov 11, 2006
    Kindersley, Saskatchewan,
    Local Time:
    3:28 PM
    It’s just shaved off and contoured to the block. Actually I’ve never had to do that. Kim
  5. Jim Lusk
    Jim Lusk Well-Known Member
    4,915
    1235
    Mar 8, 2006
    Fresno, CA
    Local Time:
    1:28 PM
    It's not necessary to copy the factory cut. Power steering works fine with the DC k-member, which uses factory '74-78 mounts that use the mount ears on the block. Add the PS and don't look back.
    • Agree Agree x 1
    • mygasser
      mygasser FABO Gold Member FABO Gold Member
      959
      619
      Aug 17, 2010
      faversham, kent. united kingdom
      Local Time:
      3:28 PM
      had you considered electric power steering assist? it cuts into the column under the dash so no engine bay issues as the manual box stays put.
      • Like Like x 1
      • 6PakBee
        260
        219
        Feb 8, 2020
        North Dakota
        Local Time:
        3:28 PM
        Jim, this isn't the DC K-member, this is an OEM. Would that affect anything?
      • 6PakBee
        260
        219
        Feb 8, 2020
        North Dakota
        Local Time:
        3:28 PM
        Yeah, I have thought about that for other vehicles but I am just too much of a purist to go that route on this car.
      • Jim Lusk
        4,915
        1235
        Mar 8, 2006
        Fresno, CA
        Local Time:
        1:28 PM
        Nope, engine should be in the same place.
      • AndyF
        AndyF Well-Known Member
        1,956
        2199
        Feb 23, 2009
        Oregon
        Local Time:
        1:28 PM
        Mock it up and see. On my car I had to chamfer the rear mount ear but I didn't have to cut it off.
      • 6PakBee
        260
        219
        Feb 8, 2020
        North Dakota
        Local Time:
        3:28 PM
        Thanks to everyone for helping. :thumbsup:
