Lets hear your 4" stroker combos
AdamR
Big Member
Bethel, CT
Im interested in hearing how you guys built your 4" strokers up. I figure if I have to redo my motor I may aswell throw some more crank at it.
I'll build up a nice short block and worry about better heads later. I'll just use the heads on the car now instead of my Magnums. This way I can use my adjustable rockers I already have so I can use a solid cam and dont have to pull my hair out looking for valve springs for the 8mm magnum valves that will work with a big cam.
Mine is still in pieces, but here is the basic combo.
340 block bored .030" over and zero decked
Cast Mopar Performance 4" crank
Eagle H-Beam rods
Ross forged pistons, 21cc dish
Speed-Pro Plasma Moly rings
Federal Mogul 3/4 groove main bearings
Clevite cam and rod bearings
ARP main studs
Scott Brown custom ground hydraulic cam
Cloyes double roller timing chain
Melling HV oil pump
Milodon 8qt pan
Edlebrock heads, straight out of the box
I didnt build my engine as it was sitting in the car when i bought it but here are the specs i know!
Original 340 block 0.030 bored
Heads are MP alu heads converted to open chamber by Hughes
MP M1 intake
Holley 750
MP 4" cast crank that has been cryod
Original shot peened and polished rods
KB Pistons ,Hughes Engines part # 2020+070 , 26.5 cc's
Piston rings are Hughes Engines part # 2114
Comp Cams V 9215 solid cam
Duration @.50 239 intake.
Duration @50 242exhaust.
Lift with 1.5 roller rockers:
534 intake
540 exhaust
Headers are TTI's with balance tube
I got it dynoed on rolling highway two days ago and got 300 bhp, the conditions in the hall were it was tested wasnt perfect! It was somwhere around 40 degrees C in the test hall. But now the engine has been tuned and runs like a beast at high rpms so im happy :D
// Chrippa
Thanks duster340!! Thats always nice too hear from people :)
On the way home the sky just opened up and it was the worst rain i have seen in years, had just cleaned it the day before , now i have too do it again :)
mikesduster said:
hey gotdart,
whats the specs of your cam??
It's pretty mild actually. My Dart is more of a street cruiser than a drag racer. So the cam has to work well with power brakes, a/c, etc.
lobe lift - 0.350/0.340
lift w/1.5 rockers - 0.525/0.510
adv duration - 283/298
dur @ 0.050 - 236/248
lobe separation - 112
I am still getting in parts! The list,W2 race heads 2.08 intake 1.60 exhaust.strip dominater intake,850 demon carb,msd 6al .cam solid roller 230 at 050 and 589 lift intake,242 at 050 and 602lift,lobe center is 114, flat top diamond pistons 11.3 comp. crane 1.6 roller rockers Callies crank, H beam rods, mopar oil pump, moroso pan,ARP bolts and studs,for now super comp headers 1 3/4 ,3 in. pipes, might go fo X pipe later,billet timing chain set .This motor will go in my 72 DEMOND 3.55 gears power stearing and brakes It will be my weakend cruiser and 11 second foot brake car with slicks!! Engine dyno 2000 says 511 HP at 5500 and 544TQ at4000
