Kim,
I just got a thick piece of plexiglass from home depot (cheap) and a baby medecine syringe marked in cc's (free, I just asked for them from the local drug store). I cut the piece of plexi to the correct size I needed to cover either a bore or chamber and drilled a hole a little bit larger than the end of the syringe. A light coat of grease on the head/block deck surface ensures it won't leak and you're ready to go.
BTW, I use tranny fluid for the cc'ng process.
