Lexan Install Help
A/MP
I have pre cut pieces of lexan for the side and door glass of my "65 Dart. I'm looking for a differnet way to install w/o using the tube systems that the Pro Stockers use
Just a thought as it occurs to me my dad is building a small experimental plane in his garage. You may want to websurf for experimental aviation construction for this kind of info. Sorry, I don't have firsthand knowledge.
How else can you support the perimeter of the lexan if you don't fabricate some kind of frame? I'm assuming you don't have a post car.
