Rapid Robert
read something way way way back about setting up to where the lifter cup is almost bottomed out all the way down (I forget the amt up from that) which would take a longer pushrod to keep the geometry correct I would assume. Would this work better than having the cup up & a certain amt of thousands preload like is commonly talked about? Thank you for your time. RR
