Lifter Storage Ideas?
mopowers
West Sacramento, CA
Do you guys know of a decent way to store lifters in the correct order if you don't have a proper lifter box?
I have use a block of wood and a spade bit, works well for push rods also....
Agree with Dicer.
Have used a 2x6 with holes drilled for the lifters, push rods and the cam laying down the middle.
Cheap effective DIY holder.
Happy Mopar:)
Arron
Pill bottles from pharmacy, number with permanent marker, or apply sticky labels. If storing long term, fill with fresh engine oil. For long term storage of a camshaft, use 2 inch PVC pipe with cap glued on one end and a clean out screw cap glued on other end, fill with oil and store upright.
