lifters
Nokke
Active Member
Motala Sweden
hello guys does any one of you no if the comp cams endurex lifters has oil hole lower down or if theres any another lifter that has it. Because i need a lifter with the oil hole lower then 1,45 inches i have measured from the bottom of the wheel to the oil hole on the lifters. The problem is that i have the oil hole on the lifter only 0,035 under the edge of the lifters bore. would be nice with many answers.
