moparstud440
Looking at Howard cams and their lifters and some have the ending DL, Apparently it means a Direct Lube lifter. Engine is a 360 LA and will have a Mechanical flat tappet cam. Are the direct lube lifters worth the extra $ and does anything special have to be done to use them over the normal lifter?
