theothergarth
What I know:
On the original switch - yellow wire on the "D" terminal is the dome light and door switches
lt green wire on the "H" terminal is the dimmer
What I need help on:
Tan wire - appears to go to the fuse block and ign according to the schematics
pink wire on the "B2" terminal - fuse block and ign as well
the "R" terminal has two wires on it - a blk one and a yellow w/blk stripe
the "B1" terminal has a larger blk w/ white stripe
Basically I need to know where the B1, B2, R, and the tan wire go to. My terminal options on the new switch are: battery feed #2 for tail lights (must be fused); parking light; headlight; battery feed #1; tail light; and dash lights (positive side).
I think the tan wire goes to the dash terminal. The rest I am not sure which goes to what.
