Can someone explain how to test why my backup lights stopped working? All other lights are working fine........
It's a 72 Demon console shift auto
The NSS switch is working properly, as the car won't start in any gear, but N and P. If I'm understanding correctly, that one switch controls both things?
Headed out to the garage now, to check the ground on the starter relay. Electrical problems are such a PITA for me.......:scratch:
Thanks for your help petty and DD. I'll let you know what I find :thumbup:
It's a floor shifted auto.
The ground on the starter relay is clean/tight and grounded when tested.
There is no power on either of the outside posts of the NSS? Does that mean I need to trace backwards thru the harness?
Hi Val, thx for your input. The early console cars had the switch attached to the shifter. I think around 69 or 70 it moved down to the tranny.
Ok, I'll admit it.........owner :error:
After reading all of your ideas and finding no power at the outside posts of the NSS, traced the wires backwards and found the 2 wires were plugged into the wrong bulkhead connector. Obviously, I was mistaken thinking the lights worked #-o
Thx to all of you for your help!!!!!!!!!!! ;) :salut:
Lights ON
What do you have for wiring diagrams, and what terminals are they hooked to?
You'll only have power at one of the two
