Lightweight (Aluminum) M/C For Drum Brakes
12many
SC
Short of calling all the aftermarket suppliers to hopefully source one with the correct specs compatible with four wheel drums, including the possible need for a residual valve if required, anyone have firsthand knowledge of an aluminum m/c (oem or otherwise) that does the trick?
Your question is somewhat vague, but if you go to the parts store and tell them you have a 1980 dodge aspen , I believe you will get what your after.
