mikedevore Well-Known Member Joined Jan 13, 2005 Messages 2,580 Reaction score 149 Location Oklahoma Apr 9, 2009 #1 Can You Install A Non-lock Up Convertor In A Lock Up Trans. & Make It Work?
M Max340 Well-Known Member Joined Sep 27, 2008 Messages 463 Reaction score 8 Location Pennsylvania Apr 9, 2009 #2 No. The LU input shaft has an extra bit on the end which will not fit the non LU converter.
mikedevore Well-Known Member Joined Jan 13, 2005 Messages 2,580 Reaction score 149 Location Oklahoma Apr 10, 2009 #3 Can A Loch-up Trans Be Converted?
D DJVCUDA Well-Known Member Joined May 26, 2004 Messages 1,075 Reaction score 34 Apr 10, 2009 #4 yes - you need a new front pump & input shaft. you also have to modify the valve body to block off the lockup.
mikedevore Well-Known Member Joined Jan 13, 2005 Messages 2,580 Reaction score 149 Location Oklahoma Apr 10, 2009 #5 Thanks
