I'm hoping someone has done this and might share some pictures.
I need to fab up a bracket that will mount up a stock style throttle cable and a lokar kick down cable to the carb flange or better yet a bracket that mounts to the two rear drivers side intake manifold bolts like the stocker.
I'll be running a air gap manifold and a 4150 style holley. I had planned on modding the stock style bracket raising carb cable the mounting up and in to account for the taller manifold and make it a streighter shot to the carb without the use of the holley mopar extentions bracket, that won't work with the lokar KD anyway.
I've got an Idea how to do this but I'd like to see anyone elses solution since they may have a different way to do this.
I do understand I could use the lokar flange mounted KD/carb cable bracket but I'm just not interested in using one of there throttle cables.
Thanks in advance.
Thanks in advance.
