MomsDuster
For those folks using a Lokar tv cable. What is your distance from throttle shaft pivot and the cable mount on the carb in relation to the accelerator mount to the throttle shaft pivot. I’ve been fighting early shifts after following the instructions for adjusting the cable. I will note that I am running a tunnel ram. Just looking to verify proper ratio.
