EL5DEMON340
I’ve got the offset shackles on my demon but wondering if they make longer rear offsets to raise the back a bit? Thanks
I've never seen them.I’ve got the offset shackles on my demon but wondering if they make longer rear offsets to raise the back a bit? Thanks
Take them to a good welder and they can be as long as you want. If the joint is beveled correctly, there shouldn't be an issue with strength.I’ve got the offset shackles on my demon but wondering if they make longer rear offsets to raise the back a bit? Thanks
i have a pair of SS springs on it now probably 30/40 years old. Seems to not have much of an arch, I’d like to raise it about an inch. Shackles are almost straight up and down. 28” drag radials on itI wouldn't use shackles to raise a car. It puts more stress on the leaf springs and can ultimately lead to them bending backwards. I've seen it on a lot of older hot rods with long shackles. The best way to raise one is a spring with more arch, like the SS springs, for example.
I would honestly run air shocks before long shackles.....and I'm not a fan of air shocks. But if new springs aren't in the picture......I
Why is that?Yeah if those are 28” tires with super stock springs and that’s your ride height your springs are toast.
