Longshot
Mopar Sam
Well Fed Member
Illinois
Probably a longshot, but does anyone here know where I can find a good printable wiring diagram for a 1967 D100? Mainly the tail, turn stoplight wiring. Thanks Sam
I have a factory manual with a wiring diagram. Not sure how well it would scan and post here.
Try the scan function on a cell phone. On a IPhone, go to the blue “file” icon, open and then hit the 3 ••• in the upper right. The Scan Document thing pops up.
Thanks for the responses guys. I'm messing with a harness that was previously hacked. I had the bed off for way longer than I thought I would, and should have taken pictures at the time.
Nowhere near large enough nor enough resolution. What you need is a device, don't know about phones, that can produce higher resolution, that you can crop and resize. Take just for trial, about 1/4 of the total so you have 4 shots that overlap. Then resize them to about 1000 pixels on the widest side
