[WANTED] looking for a 318 water pump pulley for A body.
dowboy1970
A friend of mine is in need of a 318 water pump pulley for his 72 Duster,
I believe they are all the same that year but his car is power steering with air but it is still a single groove.
I will have it sent direct to him in Tulsa Oklahoma.
Thanks in advance FABO.
I though they were the same too. Then I was looking at a reference book and it shows a difference. I have both. Pm me.
Thank you for your reply.
He needs the AC equipment car pulley for the water pump,
318, power steering, air-conditioning.
I listed that at the start.
The correct water pump pulley for a 72 duster 318 engine with single groove and AC is Chrysler part number 3418227. This number was used from 70 thru 73. The number is stamped on the pulley.
For proper alignment this pulley should be used.
If you can't find one here then search eBay with that number.
