Looking for help in NJ
Jerseystrong
New Member
New Jersey
Hi guys,
This is my first post to this forum and am looking for some friendly suggestions or help from people located in NJ. I recently purchased a 1965 Coronet 440 with a 273 in it. The motor is in desperate need of work. I suspect its only firing on 2 4 6 8. I did a compression test and got low compression on 1,3,5,7. I suspect that the head gasket may be bad. I also pulled the pan...found some metal it also looks like the valve seals deteriorated and clogged the oil pick up. The motor is pretty much done. Now, I need help either finding a member or shop that rebuilds motors or will install a used one. Unfortunately I am on a limited budget. $1500 is what I have. If you guys don't think it can be done, I will just cut my loss and sell the car as is. I live in the Central NJ area. All advise or suggestions are greatly appreciated.
That seems like a lot of money for a used engine / trans with questionable miles and condition.
The other issues you have is "what is" that 318 out of? If it's out of a truck or motorhome, you'll have to swap your 273 oil pan and oil pickup or find a "car" 318 pan. You'll have to transfer your 273 engine brackets, and possibly the manifolds, again, depending on what the 318 came out of.
If you use / don't use your original transmission, other troubles.
I believe the original 65 trans is cable shift, and the one advertised surely is not The CL might be a 727 or a 904, so the kickdown might be different.
Also, early engines had a much smaller torque converter snout than later models
In other words, if you can't find someone who is knowledgable, this could be a problem
