Looking for JUNK 426 Hemi Heads
whitepunkonnitro
Murfreesboro Tn
Rating - 98.2%
162   3   0
Like the title says, I'm looking for junk...that means stuff that has no hope of ever being repaired. Broken in half, blown out is fine. Only thing that is important is that they are iron X heads, have at least one or two stock ports and chambers intact, and you understand that they are JUNK...meaning unusable by man or beast. I'm not looking for free, but $50-$100 a piece is all I'm looking to spend. I'll take as many as you've got.
PM me with pics and prices.
what you making? coffee table? lamps?
I had a few ideas back when I was running an iron headed fueler that I'd like to revisit, and the only way to do that is with some scrap to grind and weld on. In short, I believe that in a limited pump class, like N/TF or F/C, that the ideal way to prevent over scavenging and leave a little more fuel in the chamber to be burned, is by using the stock droop style exhaust port. Also curious about building quench dams along the perimeter of the chambers to clean up some of the dead areas.
Any other questions?
I want chocolate muffins with butterscotch drops and 2.25 X 1.90 valve indentions.
