looking for some parts numbers?
sdwolff98
Member
plano texas
Hi there,
looking for some door glass parts numbers on a 1970 dodge dart 2dr ht. I am looking for the front glass guide/felt piece that mounts to the glass and goes in the vent window track channel, the plastic fastener for the lower window track, and the rear window stop plastic piece and screw. Mine have deteriorated with age and need to get part numbers to see if I can get them through dodge or an oem parts source?
thanks
Sean Wolff
plano texas
here is a picture Of what I am hunting the parts numbers for:
thanks
Sean
Sean, Can you tell from this pic which ones you need?
I'm not sure these are the parts you have pictured, but here's the info:
13 = Weatherstrip Pkg Part #2663456-7 (Part # ends in 6 for the pass side & 7 for the driver side)
30 = Rivet Part #2664256
75 = Stop Part #2894599
76 = Screw Part #9428368 (1/4" -14 X 1 1/8")
ye gads!!!!
225$ for an nos replacement youch!!! Luckily the guy in az has some for 25 each good used to get .
Thanks Again,
Sean
Glad to help and good to hear you found the parts :cheers:
found a mopar forum that has a few parts diagram books online pdf format. mymopar.com under tech section. got to doing some digging in the parts books over there and found a completely diff set of numbers but on the plus side the ones i found are what i am hunting for and still in production at chrysler :D. Also much easier on my limited budget lol.
Thanks Demon
Sean
