[WANTED] Looking for W2 rocker shafts
This what you need?
Which W2 heads are you running? The econo heads with the cupped pedestals use different shafts than the race head version that has the flat milled pedestal and needs offset drilled blocks to hold the shaft.
I have the race heads with the flat pedestals with the offset drilled blocks. I have the rockers and pedestals I just want to replace the shafts
