I just got done replacing a noisy front wheel bearing in the Dart, and I noticed that the lower ball joint had quite a bit of back and forth play.
I resigned myself to replacing it, but I checked out the shop manual, and it said looseness is not a reason to replace a ball joint if it has less than .050 inches of axial play. Mine has just a little noticeable up and down play.
So, is ball joint looseness acceptable on A-Bodies? I'm certainly not used to that...I assume the weight of the car keeps everything in check...
