I don't have any pictures of that. (Yet) What exactly ar you thinking?
You could loose the choke, but, if it isn't just right outside, your not going to start the car so easy.
im thinking no choke for better airflow (i know they already flow well, but i think it would fun to try it out)...as for starting the car easy, i know it may not start right away, but im prepared to deal with that...are you in the process of doing this mod right now?
You ain't gonna notice a difference accept a car that is a pain to start cold.
Removing the choke will require a re-jet since the air flow will increase by approx 60 cfm's.
If you did not re-jet there is about a 99% chance that the cruise circuit will be too lean and that alone will make the engine hard to start in cold weather.
You can expect about 20 more hp increase when properly re-jetted with choke removal and cold weather starting is not so bad. I build quite a few choke-less carbs and run one myself rear round, David.
You can expect about 20 more hp increase when properly re-jetted with choke removal and cold weather starting is not so bad. Besides, I want max performance! I build quite a few choke-less carbs and run one myself rear round, David.
