lost 1st and reverse in 904
barbee6043
barbee 6043
Shepherd, Texas ( SE Tx)
Friends 904 trans behind his slant. He wants to try to repair. Whats is the issue(s)????? Can he do it and he is not a mechanic!!
Could be the lever broke or backed off from the servo to rear band in which case transmission would not have to come out. I have replaced them between time runs at the track in a stacker trailer.
The last thing you typed is the key, “he’s not a mechanic”
So bring it to a trans guy and it could be fixable in the car. This is a common problem on these, but it depends what part failed.
Piston or strut failure, yes in car fix.
Broken band or linkage, no.
does the car have 1st gear with the lever in drive? the rear band is only engaged with lever in manual low or 1st . an reverse.
Mighta just blew the servo piston seal...sometimes you can fix them in the car; depending on single wrap or double wrap band.
