Lost brake & tail lights!
gtxdude
Bloomington, MN
First off Merry Christmas to all :) Has some time today went out to adjust brake pedal and a couple other things. Didn't unhook battery :( ended up sparking something under by brake switch. Put new fuse in and still don't have dash, brake or taillights. Tried another fuse, then tested all fuses, they all have power except fuse for dash, brake etc. Is there another breaker or fuse somewhere I'm missing? It seems to be pretty straight forward buttttttt having no luck! thanks
p.s. the car is parked for winter so it's not going anywhere for a few months
Went back switched a couple and everything works! Thanks for quick fix. Now can you do something about this winter thing? :)
