fishy68
Tyr Fryr's Inc.
BTW For a performance 727 it's always a good idea to toss the little spring on the servo piston and shim it solid.
Thanks, leads me to believe, its the converter more than anything. Fluid is clean. Filter was tight.
Should I be able to push up the piece that the spring sits against by hand for the reverse servo?
The spring above it is weak enough that I can probably get the clip off without compressing it with a tool to squeeze it.
What is the rest of your combo.I'd like to chime in, if I may... and I KNOW I'll offend someone here..
It's your converter. I have the same gear/tire combo as you and run 122mph at 6400 rpm in the heat. Converter is nothing special.. just a $600 TurboAction S-800 med.
I have seen this more times than I'd like to count... unless it's broke, you've got a junk converter. converter is Sooooooo inefficient, you loose all your ET in the back half cause the car don't mile-an-hour good.
PLEASE, save this scenario for the phord/shivy guys.. I beg you.
Dynamic Converters is just down the road from you. They'll treat you right, have decades worth of experience, and you'll think you added 100 more hp.
What stall is the converter you have.
Is that their 11" converter
Trailbeast have you installed one of the super servos?Cleared it out.
The billet ones are best, and will keep that from ever happening again.
Check A&A transmissions online.
These steel Super Servo's are nice also.
Dodge A727 A518 46RH 46RE Transmission Low Reverse Super Servo Billet K029 | eBay
I can't seem to get the seal to slide past the retaining ring groove. Without the seal it slides right in.
I don't see how its even going to slide in with the stabilizing ring on it.
Any suggestions?
First I tried living it with transmission fluid, then I tried petolum jelly, as stated in one of the rebuild videos.
Any suggestions?
Thanks trailbeast, I will give that a tryPut a hose clamp around the seal and tighten up pretty good, then stick it in the freezer for 20 min or so.
Be ready to put in in AS SOON as it comes out of the freezer.
Thats a good idea also. Not sure it would work with the stabilizing ringFreezing it is a good trick. I have also used a very thin feeler gauge to fold the seal down as I push the servo in. Slide the feeler around the bore as you give it a little pressure.
My 2 cents; l stick it all the way down into the bore sideways, then start to straighten it up, all the while making sure it has gentle contact with the bottom, and maybe sometimes give it a little twist as it levels off. Then l pull it halfway out, cover the port with my thumb and try to push it in to pressure test it.
I should. And I probably will. It's a pain. And I either fight with it around the headers or take them loose, which is also very fun.Take it out.
Doesn't look like either to me. Maybe it's just my monitor but it looks like small gravel here. Either way about it the trans needs to come out and gone through and everything, and I mean everything, needs flushed good to get that crap out or you'll have the same problem again in no timeAny ideas on if it looks like clutch or band?
Post some pics of the worn parts. Kim
There is no way a properly rebuilt trans would do that.Washer goes here.
Half missing and I pulled the trans all apart and never found the other half.
View attachment 1715880625 View attachment 1715880626
