Mopower71
Speed Demon
What would have been done wrong to do this?There is no way a properly rebuilt trans would do that.
I added some picturesWhat do you mean by "disintegrated"? tiny pieces or large areas coming off in one piece? I always make sure that all the fibers in the front pack match.
Thanks.Moisture or anti-freeze will cause the glue to let go and the friction material fall right off the steel discs. Vehicles that sat for a decade or radiators that cracked can cause that.
YesDid it have type F fluid in it? Kim
But, but , but, the recommendation was to run type f.There in lies your problem. Type F deteriorates seals. Then the clutches get burned/ fall apart. Ford was having a big problem with tranny failures in the early 70s. The switched to type A/dexron. No more problem. Kim
