Lots of Mopar Parts for Sale!!!!!!!
longlakevintage
New Member
Long Lake, NY
Rating - 0%
0   0   0
Hey Everyone!
I am selling a lot of Mopar parts!!!! Take a look at the list and see if there's anything you're interested in! If you have questions, want pictures, or want more information please let me know!!! Thanks
CH228 (5213033) - Cap Package (quantity 4) - $14.99/each
CH229 (5213034) - Cap Assembly (quantity 2) - $14.99/each
CH321 (3874401) - Rotor (quantity 6) - $5.99/each
CH323-L (4240450) - Rotor Assembly (quantity 1) - $5.99
1115100 - Front End Oil Seal Plate Package (quantity 1)
1139291 - Bearing Cup (quantity 1)
1139292 - Bearing Cone (quantity 1)
1139293 - Bearing Cup (quantity 1) - $14.99
1139294 - Cone and Roller (quantity 1)
1189230 - Shaft (quantity 1)
1189232 - Shaft (quantity 2)
1192383 - Joint (quantity 1)
1320561 - Fluid Coupling Seal Ring (quantity 1)
1450303 - Power Punch Piston Rings (quantity 1 Pkg.)
1450504 - Universal Joint Package (quantity 1)
1599683 - Moulding (quantity 1)
1752307 - Universal Joint Package (quantity 1)
1789889 - Gasket (quantity 4 in pkg)
1791195 - (quantity 1)
1879520 - Gasket Set (quantity 2)
2084005 - Std. Bearing (quantity 1)
2883541 - Spacer (quantity 1) - $9.99
2911012 - Heater Switch (quantity 1)
2932990 - Clear & Ident LP Lens (quantity 3)
3004190 - Cigar Lighter Element (quantity 1) - $14.99
3420599 - Tail Lamp Lens & Gasket (quantity 1)
3432324 - Shim (quantity 1) - $6.99
3432325 - Shim (quantity 1) - $28.99
3432326 - Shim (quantity 1) - $13.99
3432327 - Shim (quantity 1) - $9.99
3432332 - shim (quantity 1) - $16.99
3432333 - Shim (quantity 1) - $15.99
3432334 - Shim (quantity 1) - $14.99
3432336 - Shim (quantity 1) - $31.99
3496290 - Spacer (quantity 1) - $3.99
3582628 - W/ Stri (quantity 1)
3582629 - W/ Stri (quantity 1)
3587282 - Lamp (quantity 1)
3620756 - Lamp Package (quantity 1)
3621815 - Lens Package (quantity 1)
3621893 - Lens & Gasket Assembly (quantity 1)
3632597 - Eye Bolt/Nut (quantity 1)
3632975 - Bearing (quantity 1)
3723628 - Shim (quantity 1)
3723629 - Shim (quantity 1)
3723631 - Shim (quantity 1)
3723635 - Shim (quantity 1)
3731309 - Mirror Assembly Front Drive O/Side Bright (quantity 1) - $89.99
3744839 (4026487AB Supercedes) - Bearing Kit Crankshaft (quantity 2) - $86.99/each
3871286 - Strike (quantity 1)
3879578 - Moulding Package (quantity 1)
3882450 - Strike (quantity 1)
4094806 - Bearing Package (quantity 2)
4095338 - Cross Over Choke (quantity 1) - $73.99
5212533 - Bearing (quantity 1)
5240509 - Gasket (quantity 3)
These are the Mopar catalogs I have:
1974 Mopar Chrysler Parts Catalog - $129.99
1977 Mopar Chrysler Parts Catalog - $79.99
1978 Mopar Chrysler Parts Catalog and Upholstery Manual - $99.99
1979 Mopar Chrysler Parts Catalog and Upholstery Manual - $99.99
1980 Mopar Chrysler Parts Catalog - $69.99
1981 Mopar Chrysler Parts Catalog - $59.99
Large Empty Mopar Catalog Binders (quantity 2) - $15.99/each
** I am considering all reasonable offers as well. All items can be shipped on flat rate box shipping rates (varies on size of box and can range from $4.90-$15.00). We will combine shipping for more than 1 item purchased. We cannot allow returns on parts that are not compatible with your car or for regret in your purchase. Please let me know if you would like more pictures or information, thanks.
You might do better if your ad was in the For Sale section.
Ken
Hi,
I've just read your post and am wondering if you still have the binders for sale? I'm looking for two of the grey early 90's Chrysler binders.
Regards,
Adam
