jamey
440 m1 single plane intake nice shape,and all threads are good. does have a hole drilled for a vacuum port. $125 plus shipping
Indy 440 2d dual plane intake. $250 shipped in the US.
Race pumps mechanical fuel pump with regulator and some extra seals. Works perfect. Current setup has an electric pump so I have no need for this. $350 shipped in US
Smith Brothers 3/8 push rods, just under 9 1/4 length. Ball/Ball ends, perfect shape only 1500 miles on them. $110 shipped in US.
Comp Cams double valve springs, keepers and retainers. 953-16 with 148 on the seat and 456 open. They have 1500 miles on them. 150 shipped in US
Pro Comp Holley style 850 cfm main body with no choke tower. Worked fine, just too small for my application. $60 shipped in US.
70 440 core. Not an hp motor, has steel crank, your choice of heads (452,516,346). Missing intake, valve covers, oil pan, water pump, distributor. Turns over. $300.
1970 440 block, non hp, block and main caps. Has a minor repair to front of block in a non stress area. $100.
I have a 1967 318 2bbl motor with 50,000 miles. Heads had been redone, runs perfect. Complete from air cleaner to oil pan. $400.
8 3/4 741 case with 3.23 and powerlock. Small yoke. Just clean up and go dirty from sitting. $300. Located in NW PA. Pm me if interested. Will provide pics if needed.
I can provide pics for anyone interested. Everything is nice and not junk. PM me if interested. Thanks Jamey
