504DusterIR
Hello how are y'all doing ?, I changed out my headlights an now my low beams won't work.My high beams turn on but low beams won't does anyone have any advice on what it could be ?
Ok that you , I looked up dimmer switch connectors,is it as easy as just matching up the wires to same ones? There are not colored they all blackThat will do it!
That LOOKS like a mess. Are the other two wires all mashed up? That is your dimmer switch for the HEADLIGHTS. Think about rocketing down the road at 70.........and........darkness.
What year is the vehicle? depending, you can download a free factory service manual from MyMopar.com
It's A 72 and they are mashed up I found dimmer switch connectorsThat LOOKS like a mess. Are the other two wires all mashed up? That is your dimmer switch for the HEADLIGHTS. Think about rocketing down the road at 70.........and........darkness.
Two of your wires are still attached. So just be sure the location of each wire in the new connector is the same as the oldOk that you , I looked up dimmer switch connectors,is it as easy as just matching up the wires to same ones? There are not colored they all black
I just made that a sticky.
OkTwo of your wires are still attached. So just be sure the location of each wire in the new connector is the same as the old
So much good info , Yea I wasn't sure if I could just reconnect the wire that split due to the other part of the wire being inside the connector housingSources for Chrysler type wire terminals | For A Bodies Only Mopar Forum
How to remove a female terminal from the connector housing.
[/URL]
How to crimp open barrel terminals
http://[URL]https://www.forabodiesonly.com/mopar/threads/a-bit-of-wiring-101.506706/#post-1973710272[/URL]
A neat way of splicing
[/URL]
