mechanic190
Well I think I got my combo for car figured out, just wanna post it on here and see what you all think, what'd you'd change, and whatever else you wanna say.
77 440 out of a motor home
Factory rods, cast crank, and pistons factory size just gonna bearing a re-ring
dual 600 vacuum sec holley 1850-2s sitting on a stage II Weiand tunnel ram
Ported and Milled 906 heads (just an old pair my dad used to run)
Hughes 264 268 cam with 1.6 rockers 633 651
MSD 7 ignition
Gonna go in my 72 dart. 4 linked, caged, 32x14x15 slicks, dana 60 with 4.56 gears, 4500 stall converter, should weigh around 3100 lbs.
Not gonna bore or machine the block at all just re-ring and go see what she does. Carbs are getting kits, rear metering blocks from quickfuel so i can tune seconaries and power valves blocked off.
MSD 7 ignition
