Located in NY 12538 but will deliver to Carlisle Thursday or Friday at the show with $100 deposit.
1986 Lock up A999 core. Needs rebuild or use low gear set and steel planetary's and wider 5 disc front clutch retainer with light machine work in your 904.
Low gear/wide ratio gear set is 1-2.74, 2-1.54, 3-1:1
Torque converter included. I would consider the converter a core as well.
$250 OBO.
Thanks FABO!!I
$250 OBO.
Thanks FABO!!I
