Check out Summit. a good cam would be the Comp 262 or the 268, with the 901 springs. You can also get the kit for about 350. It comes with everything you need including new timing chain and gears.Preformer intake and a 600 to 650 carb like Rumble said. Holley or Eddy. For what your lookin for, i think its a nice combo.
If you want to go a step further, have the the deck squared and go with some KB 167 pistons set at Zero deck.
I see BJR is in this thread, and he has alot of good combos. I sure he will help. It all depends on what you want.
