Lower ball joint bolt 9 1/6 ×?
ratvon
central ohio
I'm doing a disc brake conversion on a 68 barracuda what hardware do I need to bolt on the lower ball joints. Diameter thread and length. Washer and stover nut? Found out the drum style bolts are too small
I just went through this..... The Length that I cam up with was a touch over 2.625". The thread pitch is 9/16-18. I used a standard height Jam Nut and then milled them down to a height which cleared the Shields, Calipers, and still locked the Bolt down.
I never found OEM Hardware and got everything from Fastenal and just cut/threaded/milled the Fasteners. Maybe someone will chime in as to where you can get the pieces as it took a while to make it all fit. The end result is everything worked out great.
Good luck,
JW
5/8size, 18 threads per inch and 2 3/4 long (give or take) for 73-up disc spindles and can be found at most big box home supply stores. I bought mine from Menards
Grade 8, Hex Head 58-18 x 2 ¾” zinc yellow and 2-Grade C or grade 8) Lock-nuts..JPG
Good luck,
JW
2 and 5/8 from the bottom of the head correct? Or are you talking overall length?
5/8 is the bolt size/diameter and the 2 3/4 is the length from the bottom of the bolt head down
Ya I was replying to the other the guy but 5/8 ×2 3/4 worked for you and wasn't too long or too big ...I'm pretty sure that it is a 9/16- 18 ×2.625 that was used
I brought my ball joint and spindle with me to check and I think I used a 3" because they didn't have 2 3/4. I did shave the head down for clearance of the rotor
Oh so you brought your bolts out through the ball joint and the heads were inside again up against the rotor
I have a wheel off and will measure what I did for you. There is a Dorman number that will suffice for the bolts I believe....
JW
I just noticed that you didn't mention which disc set you are swapping to. Which one are you using?. I think the KH uses the 9/16 bolts and the later large disc's use the 5/8
The KH 4 piston set up uses smaller bolts 9/16 I think. Do you have a Menards,Fastnal or HomeDepot near by? Get the 5/8x16x 2 3/4 or 3" and cut off the extra
