Cope
Fusing with fire
I'm swapping my drums on my 71 dart to 1973 disks.
Do I need to swap the LCA, or can I use my original ones?
Typically you need the disc brake spindles but I think Dr diff sells a $20 shim to make them work. it's what I would have done had I not had the 73 discs already.I'm swapping my drums on my 71 dart to 1973 disks.
Okay yellow rose write your check! LOLI orders the whole shebang (all the parts, spindles, LCA, UCA, Everything) from white punk nitro. I just rebuilt my front end like a year ago, so if i dont have to clean, paint and install now bushings in the 73 LCA that would be nice.
NoI take pay pall....
So...... do I need to swap the LCA?
No sway bars, drag car. In fact I just threw front and rear sway bars in the scrap bin....
Just to be clear, only the upper ball joint is the large one right?
I can use my old 71 LCA, correct?
I know Mancini sells the ball joint sockets, anyone know of another vendor or some other way of R&R ball joints with out the socket?
I think the last one I bought (small ball joint socket) was like 70 bucks and took forever to arrive.
you're correct I knew there's something you had to do if someway the conversion to make it easier and I figured if I just babbled some stupid crap out someone like yourself would come in and make sure it was corrected thank you.Exactly. I don’t know why j par keeps talking about upper ball joint spacers since you asked about the lower control arm.
The lower ball joints have different bolt spacing on the earlier drum spindles, but you just buy a disk brake lower ball joint, no need to change the LCA at all.
My bad I thought he was just asking about the entire deal switching over from drum brakes and this is exactly what I was talking about.
Actually I use my phone most the time and only a few times do I actually turn my phone sideways and can see the post counts and stuff like that.Admit it, you're bored, and just trying to beat Memike's post count . lol
I will admit that I'm bored most of the time. But trying to get the post count? LOLI try to keep it brief, accurate and pertinent.
"Just the facts ma'am, just the facts". lol
Cheers.
Autozone has them to lend.I know Mancini sells the ball joint sockets, anyone know of another vendor or some other way of R&R ball joints with out the socket?
oh I forgot to mention this always drive people nuts but I've never used anything but a pair of old channel locks on those.Autozone has them to lend.
