Grassy, go to firmfeel.com. On their website you can see how to make your own sway bar tabs. Possibly out of 3/8 inch thick L shaped steel. You just have to drill a hole in each control arm to bolt the tab on. I have a set of lower arms but shipping may be outrageous.
I couldn't find the instructions on that site..I followed a link on the bigblockdrt site but the pictures were deleted by the admin..
I also found this on our site..
Cred goes to the original poster :
To make a 73-76 tab:
Get some 2" x 3" square tubing or 2" x 3" channel.
Cut the end across the 3" side diagonally 3" back to make a 45 degree cut. That will leave you a channel cross section that is 2" wide with two 3" tall legs.
Cut those two legs 3/4" back from the tip to make the legs 2 1/4"
Drill a 5/8" hole centered 2" from the back of the legs
That mount will be about 1/2" lower than stock. Not a big deal, you can just run a shorter end link spacer to compensate. You want to set the sway bar arm level to the ground at ride height. That will also be level to the sway bar tab. The factory tab is angled down slightly toward the center of the car. The angle is relative to the LCA flange.
You could make the piece out of 4x2 square tubing or 4x2 channel and put a notch in it like this. That would put them more at the factory height, but they are not as simple to make.
