lower control arms
n8ling
Langford BC
What is the trick to getting the lower control arms and the torsion bar adjustment off of the torsion bars, are they just seized or am I missing something. The k-member is out and all thats left are the lower control arms on the long bars, if there are snap\split rings on there I can't seem to find them. Once everything is off will they just slide out the back cross member??
There is a spring clip in the rear of each tortion bar mount that has to be removed before the bars will slide out the rear. If you use a pair of needle nose pliers you can squeeze the little tabs together then just pull them out.
When I removed the front suspension & K-member from my 66 Valiant, I had to take a large hammer and just drive the suspension slowly off the torsion bars, because they would not go out through the rear monuts. I put those things in there about 20 years ago, and figured it would be a snap to get them back out - NOT!! Once they were off in the front, I just gave each one a light tap with a hammer and they then slid out the rear. Hope this helps.
They're probly seized. I got my passenger side off with a little heat and blaster, but the driver side I had to torch off. Just remember to take the rubber bumpers off of the control arms before applying any heat----- -
I didn't(duh).
If the control arms are loose from the K-member, it's a simple matter to work the arms forward and pull the bars through the T-Bar support, then just heat the sockets on the control arms and remove the T-bars.
Mark.
