[SOLD] Lunati 10200703LK cam and lifters
supertruck
Unretired Old Fart stock car racer
Gloucester, Va
Decided to go with a solid cam instead of a hydraulic flat tappet cam in my 340 build. The cam and lifters were installed but the engine is till on the stand so no wear on any pieces. .494 / .513 lift, duration at 0.050 is 226 / 234. Also have a set of new Crane 99278 anti-pump lifters for a LA small block. $150.00 shipped for the Lunati cam / lifters, $75.00 shipped for the Crane anti-pumps.
Just to let anyone know this is an awesome street cam. I'm running one in a 360 with W2 heads and it runs super. It will work with power brakes also.
Agreed. I have this same cam kn my 340 and it was a noticeable improvement over my previous 268 purple shaft cam. Highly recommend for a street/strip small block.
Interested if sale falls through. I was looking at this cam for my 340. My questions is what valve springs are you guys running? My heads are currently stock with stock rockers and springs. I was planning on just changing the cam, and I figured springs too and leave stock rockers.
Thought? Opinions? Suggestions?
Thanks!
Cam and lifters are sold. As to valve springs, I'm running the springs that came with the Edelbrock heads. Had to shim them to get the correct height, but my engine guy said they were plenty good for the cam.
