71duster06
One last question. Would it be an option to use the Lunati Voodoo 60403 cam with Hughes 1110 single valve springs? It looks like the hughes springs are recomended for similar spec Hughes cams but I want to make positive its a good option. I am hoping to stick with a single spring but if this doesnt work then Ill have to get the heads machined. Any input will help a lot!!!
Hughes 1110 Single spring spec
120# @ 1.660' INSTALLED 310# @ .550' LIFT
$5.90
Installed Height/Pressure: 1.660"--120#
Pressure @ .450" lift: 280#
Pressure @ .500" lift: 300#
Pressure @ .550" lift: 310#
Coil Bind: .620" lift
Outer Spring ID/OD: 1.033"/1.440"
Type of Spring:Single w/ damper
Lunati Spring spec
Part Number73949LUNhttp://www.summitracing.com/search/Part-Type/Valve-Springs/ Number of Springs Per ValveDualOutside Diameter of Outer Spring (in)1.440 in.Coil Bind Height (in)0.950 in.Damper Spring IncludedYesSpring Rate (lbs/in)363 lbs./in.Inside Diameter of Outer Spring (in)1.070 in.Inside Diameter of Inner Spring (in)0.745 in.Valve Spring StyleStandardCoatedNoQuantitySold as a set of 16.
$5.90
Lunati Spring spec
