What lifters are you using? Lunati's had their share of troubles with their lifters collapsing. Oh, I do have a new set comp cam lifters and the cam is the 703...…
do you have a particular lifter in mind you'd run with the Lunati 703 cam?get the lifters with the snap ring not the paperlip
Change the clip to snap ringsget the lifters with the snap ring not the paperlip
Do you know what size the snap rings are? Tried to figure that out but must have been too drunk or stoopid... maybe both!Change the clip to snap rings
Maybe I'm crazy..Do you know what size the snap rings are? Tried to figure that out but must have been too drunk or stoopid... maybe both!
Can you run solid lifters on a hydraulic flat tappet cam? 65'Get solid lifters and adjustable rockers and quit playing tiddlywinks....
Yes.Can you run solid lifters on a hydraulic flat tappet cam? 65'
the snap rings in the link fit comp cam 822 lifters?Maybe I'm crazy..
Being that lifters a multi-piece deal it wouldn't be cost-efficient to have to make larger lifter cups and separate snap rings as well for a Chrysler when all the others use a smaller lifter body... so im thinking they start with the same core and 'cut less off of it' so that it's a .903 '904' instead of .842 or other smaller lifter bodies...I mean...call me crazy...just seems logical. Lol
Hydraulic Lifters Snap Rings - Lifters
I've never done it, but doesn't it make the cam act smaller because of lash instead of preload?Yes.
So you both ran Solid lifters on your Hydraulic Lunati cams? Interesting. What brand?Solid.
first thing I did was have my purple performance camshaft that was hydraulic ground into a solid lifter camshaft... No I have never ran solid lifters on a hydraulic lifter cam except after it had been ground...So you both ran Solid lifters on your Hydraulic Lunati cams? Interesting. What brand?
Sealed Power HT2011. They are out of the others. Melling and Sealed Power have the same part number. Makes you wonder doesn't it? 1970 DODGE DART 5.2L 318cid V8 Valve Lifter | RockAutoWhat lifters are you using? Lunati's had their share of troubles with their lifters collapsing. Oh, I do have a new set comp cam lifters and the cam is the 703...…
Solid.. what else...What lifters are you using?..…
Why do you keep looking for performance out of hydraulic lifters?...
read the title again, then read my question in post 1 again. And read it slow this time.... Question is specific about Lunati Hydraulic FT cams, and what lifters people have used on them. That's why it says Lunati Hyd FT cam USERS... in the title. Are you a user of a Lunati FT Hyd cam?? GREAT, please tell me what lifters you used, i'm interested.Solid.. what else...
I wouldn't use hydraulic lifters on a performance build, why do you? Is there any advantage?...read the title again, then read my question in post 1 again. And read it slow this time.... Question is specific about Lunati Hydraulic FT cams, and what lifters people have used on them. That's why it says Lunati Hyd FT cam USERS... in the title. Are you a user of a Lunati FT Hyd cam?? GREAT, please tell me what lifters you used, i'm interested.
