Magnum 360 into 70’ Dart
WacDad Miller
Active Member
Illinois
What oil pan are people using to install a Magnum 360 into a 70’ Dart, aftermarket, fabbing your own, front sump, rear sump?
LA360 passenger car pan, center sump. Front and rear sump pans are for trucks, not A bodies or any car for that matter. Get the passcar oil pickup and dipstick/tube while you're at it, too.
Check/search the Magnum swaps section of this forum, and also magnumswap.com for the complete lowdown on the swap.
I used a repop 360 car pan. Works great, though the back rail was very, very close to the magnum flexplate, so I had to trim the pan about 1/4”.
The pan also doesn’t fit totally right in the timing cover area with the magnum one piece gasket. There’s a ton of info on here about how to make it work. I have had no leaks.
