roosduster
Colorado Mopar
What are some opinions of how Magnum 500s look on Dusters?
It may just be the picture that they used, but I like the Wheel Vintiques better...
Maybe this will help a little. Only pics I have of factory ford magnums on a duster.
:shaking2:
Thanks, what size are those wheels? Do you know?
Man I do not know. I vaguely remember them being 14 x 7 or 6.5. I am pretty sure they were 14. I am sure you would want to run 15 or bigger.
Also, here is an interesting repro but has deep backspace 5.9" and requires machining the center register out slightly to the proper diameter to fit front mopar hub (maybe rear hub register too). A bit of research required to make these work. Upside is 18 inch by 9 aluminum and the price. 144$ each.
http://www.americanmuscle.com/9404-magnum-18x9.html
No problem! I would run same size rim front and rear. Bigger diameter rim = less sidewall = more control.
