moparmarkk
Hi, will the stainless steel tubular header from a 5.9 magnum fit a LA engine? and if so will these pipes work in a 75 A-body with 318-360? thanks , mark
Well, what chassis were the headers designed for?Hi, will the stainless steel tubular header from a 5.9 magnum fit a LA engine? and if so will these pipes work in a 75 A-body with 318-360? thanks , mark
Stainless steel factory tubular headers? We're going to need more info and pics .these are the factory dakota pipes, mark
Cast iron manifolds from the factory in every Magnum Dak/Ram/van that I've ever seen or heard of. Even the Dak R/T, which it would have to have been, since you say it was a 5.9 Dak.these are the factory dakota pipes, mark
Just pointing out they're not factory units as the op seemed to implyYes Sir ,,,,,but they don’t fit an A body either .
Tommy
Just passing on the info.was only going by what the seller told me, pricy also ,thanks for the info, mark
