magnum guide plates
Magnum or LA block ?
Getting the roller tip centered over the valve tip
would be more getting the pushrod length right.
I'm not talking about the scrub or pushrod length....I'm talking about getting the best guide plate to center the rocker from side to side.
I ain't got that far yet so I am strickly thinking out loud, what about elongating the hole in the square pedestal so it can be shifted over slightly to center the rocker when you torque the bolt down in that position. I cant see the guide plate solving this but again I am a mag newbie (working on my first LA/mag eng)
Crane conversion kit,Comp rockers . Mine seems to line up well,on E/Q OEM replacement Magnum heads.
