ddart cart
The flawless 360 magnum steamer I just bought is shot, and being on the road by late may is probably not happening.
I got a line on a bored over 360 la that never got assembled, and I definitely want to buy it.
At that point I will have:
A complete magnum with a bad block 70k
A complete running 1974 5.2 135k
A bored over 360la with crank, pistons on rods, and cam bearings in, no cam.
A new air gap with la and mag bolt up
A new kevco pan and pick up
A fresh rebuilt 650 thunder
A new adjustable chain
A new standard volume oil pump
A full felpro gasket set for magnum
A timing/water gasket set for la
I want to use the magnum heads on the bored over la, which I think requires amc oil through lifters, hollow push rods, and a cam with oiling holes to match? I tried to search the parts and came up confused as usual.
I’m still poor and prefer avoiding $1200 machine shop visits.
Can the crew provide any parts I missed, part numbers, or clarifications for the novice? Is it an expensive endeavor? Should I consider another plan, moving forward?
Thank you in advance,
Doug
Doug
