magnum intake
cwkerr007
Beaumont,Texas
whats the deal with all these airgap intakes do they have one with a la bolt pattern that has the magnum thermostat set up ?????? I bought this useless crosswind intake that has both patterns but has the old t stat set up so why have the magnum bolt pattern if you can't hook up the belts or mount your comp. can someone give me a link to a la style bolt pattern that has the magnum t stat ???
There is no intake that I know of currently available that has LA bolt pattern and Magnum thermostat housing and bypass hose setup.
The genuine Edelbrock RPM air gap for Magnum is the only one currently available with the Magnum thermostat and bypass hose, but it is only available with Magnum intake bolt pattern.
All of the Chinese air gap copies I have seen with dual LA and Magnum intake bolt pattern have the LA thermostat and bypass hose setup.
If you really want an easy bolt on set up with LA intake pattern and Magnum thermostat and bypass hose setup you will have to find one of the old, out of production, Mopar M1 intake manifolds that were available years ago. These were offered in dual plane configuration (not an air gap design) and single plane version with or without fuel injection bosses. Many configurations available back then.
Thanks, I guess I'll have to make brackets and move the comp I was going to have to do it anyway because I have a tunnel ram for it. I was going to break the motor in with the air gap though but i guess not till next week now damn
The Magnum bolt-hole stands can be milled off (ground if you're good at it) and the intake redrilled for the LA intake pattern. The holes are in virtually the same place, but you'd definitely want a drill press. Hand drilling would be frustrating at best.
