[SOLD] Magnum M1 EFI Intake
Mopar Sam
Well Fed Member
Illinois
Magnum M1 EFI intake, this is the EGR version, however, it is blocked with a pipe plug in the plenum. You can remove the plug if you want to run the EGR. These are good intakes if you are using a stock EFI system. A stock throttle body bolts to it without an adapter. It includes the install kit so you can run stock Magnum fuel rails.The intake is used, but pretty clean. I also have some stock fuel rails I will throw in if you want them.
Located in Sullivan IN 47882
$450.00 shipped in continental US
