Magnum manifold install
Tad
Not here
OK so I finally picked up my 5.9 magnum manifolds. Just looking at them and the car now. My first thought is I’m going to have to reposition the oil filter which is currently on the 90° adapter. I’m assuming I can just flip the adapter around 180 deg the other way so it’s pointing towards the front of the car. Any input on this?
You can, or you can remove the adaptor, and run the filter threaded into the block with 2 parts and a gasket. PM sent
Dakotas have straight filters and there's no interference.
Biggest issue with magnum manifolds is they sit on the power steering adjustment.
If no PS, then you should be good?
Manual steering on my car
Do they still make the kit to mount filter out on the render well
