Doesn't matter what the EFI management system is, Crank Sensor issues still hold up the boat. My car is a four-speed, and I'm running a 5.9. I've heard of some guys stabbing the flexplate in behind the 4-speed flywheel and are off n' running but I never saw how that would work, my motor didn't have enough room between block face and flywheel.
Honestly, I literally have a crank pulley sitting next to my mill waiting for 8 holes. The bracket to mount the sensor: Cake.
So many options, all the same issue. I could make a plate to bolt on top of the crank pulley. I could machine the pulley itself. I make a trigger wheel.
adding a bolt-in trigger wheel (Phord shown, sue me):
The issue: How do I "clock" 8 holes onto a crank pulley that can be mounted 6 ways (one for each clocking on the damper) so that crank trigger point for cylinder number #1 is always on #1? You have a 2 out of 3 chance of screwing it up! I've heavily contemplated trying it with the later 1-piece damper/pulley, which
is clocked. I'm not sure of the interchangeability on old-style and new-style.
This morphodite beast shows the issue best. Picture it, you can rotate the pulley to six places, and picture how the 5 (or 8, natch) holes would be in different places.
This guy claims this:
http://www.delmarvadodge.com/photo/crankpulley
That sounds like a Pain in the ***. This could be so much simpler.
The one-piece deal. Dorman makes these, too, but I see 'em factory on later engines:
I'm not sure about cutting 8 holes in these, because of the potential balance issues, and a fear of introducing a stress riser that could cause it to go boom. These are cast, the two piece use a stamped steel pulley; it's much stronger and I have no fear of machining it...just can't clock it.
I think that's why the factory put it on the flexplate to begin with. The offset bolt guarantees that the flexplate is clocked the same, every time.
Thoughts? Anyone has a good idea, post it up and I'll machine it, and several more asap. I'll put 8 holes in a pulley and make a CKP bracket right quick, but you gotta have your head on straight about timing it if you wanna try it.
